codes défauts Nissan qashqai
Messagepar titou78 » Dim Nov 29, 2015 10:13
Voici tous les codes défauts pour nos Qashqai ,en anglais pour l'instant :wink:
Nissan Specific Trouble Codes Code Description
P1105 MAP/BARO Pressure Switch Solenoid Valve
P1126 Thermostat Function
P1130 Swirl Control Valve Control Solenoid Valve
P1148 Closed Loop Control (Bank 1)
P1165 Swirl Control Valve Control Vacuum Switch
P1168 Closed Loop Control (Bank 2)
P1320 Ignition Signal
P1211 ABS/TCS Control Unit
P1212 ABS/TCS Communication Line
P1217 Engine Over Temperature (Overheat)
P1335 Crankshaft Position Sensor (REF)
P1336 Crankshaft Position Sensor (CKPS)
P1400 EGRC Solenoid Valve
P1401 EGR Temperature Sensor
P1402 EGR System P1440 EVAP Control System Small Leak
P1441 Vacuum Cut Valve Bypass Valve
P1444 Canister Purge Volume Control Solenoid Valve P1445 EVAP Canister Purge Volume Control Valve
P1446 EVAP Canister Vent Control Valve (Closed)
P1447 EVAP Control System Purge Flow Monitoring
P1448 EVAP Canister Vent Control Valve (Open)
P1464 Fuel Level Sensor Circuit (Ground Signal)
P1490 Vacuum Cut Valve Bypass Valve (Circuit) P1491 Vacuum Cut Valve Bypass Valve
P1492 EVAP Canister Purge Control/Solenoid Valve (Circuit)
P1493 EVAP Canister Purge Control Valve/Solenoid Valve
P1550 TCC Solenoid Valve
P1605 A/T Diagnostic Communication Line P1705 Throttle Position Sensor Circuit A/T
P1706 Park/Neutral Position (PNP) Switch
P1760 Overrun Clutch Solenoid Valve (Circuit)
P1003 EDC15C2 - External intervention on the flow. Automatic gearbox function information; value received incorrect
P1100 MAF (Mass Air Flow) sensor intermittent / Systems check not complete
P1101 MAF (Mass Air Flow) sensor Out of self test range
P1102 MAF (Mass Air Flow) sensor in range but lower than expected
P1103 MAF (Mass Air Flow) sensor in range but higher than expected
P1104 MAF (Mass Air Flow) ground malfunction
P1105 Dual alternator upper fault
P1106 Dual alternator lower fault / MAP (Manifold Absolute Pressure) sensor circuit Intermittent high voltage
P1107 Dual alternator lower circuit malfunction / MAP (Manifold Absolute Pressure) sensor circuit Intermittent low voltage (EDC15C2-Swirl solenoid valve)
P1108 Dual alternator battery lamp circuit malfunction / Baro to MAP (Manifold Absolute Pressure) sensor comparison too high. EDC15C2 - Fan high speed circuit. Open circuit or short circuit to earth.
P1109 Intake air temperature (IAT) B sensor intermittent
P1110 Intake air temperature (IAT) sensor (D/C) open/short.S2000 - Adaptation of the quantity of air entering the manifold. EDC15C2 - Airconditioning cut-off circuit. Open circuit or short circuit to earth.
P1111 Intake air temperature (IAT) sensor circuit Intermittent high voltage
P1112 Intake air temperature (IAT) sensor circuit Intermittent low voltage
P1113 Intake air temperature (IAT) sensor circuit open/short
P1114 Engine coolant temperature (ECT) sensor circuit Intermittent low voltage / IAT - B sensor circuit low input
P1115 Engine coolant temperature (ECT) sensor circuit Intermittent high voltage / IAT - B sensor circuit high input
P1116 Engine coolant temperature (ECT) sensor out of range
P1117 Engine coolant temperature (ECT) sensor circuit Intermittent
P1118 Manifold absolute temperature sensor circuit Low input
P1119 Manifold absolute temperature sensor circuit High input
P1120 Throttle position sensor (TPS) out of range
P1121 Throttle position sensor (TPS) circuit Intermittent high voltage
P1122 Throttle position sensor (TPS) circuit Intermittent low voltage
P1123 Throttle position sensor (TPS) In range but higher than expected
P1124 Throttle position sensor (TPS) Out of self test range
P1125 Throttle position sensor (TPS) circuit Intermittent
P1126 Throttle position sensor (TPS) circuit (Narrow range) Malfunction
P1127 Exhaust not warm Downstream oxygen sensor
P1128 Upstream heated oxygen sensor (HO2S) Swapped
P1129 Downstream heated oxygen sensor (HO2S) Swapped
P1130 Lack of HO2S switching - Adaptive fuel at limit
P1131 Lack of HO2S switching - Sensor indicates lean
P1132 Lack of HO2S switching - Sensor indicated rich / EDC15C2-Catalytic convertor temperatures
P1133 HO2S 1 Insufficient switching
P1134 HO2S 1 Transition time ratio
P1135 Pedal position sensor circuit A Intermittent
P1136 Fan control circuit Malfunction
P1137 Lack of HO2S 2 switching - Sensor indicates lean
P1138 High pressure rail sensor fault / Lack of HO2S 2 switching - Sensor indicates rich
P1139 Water in fuel indicator circuit Malfunction
P1140 Water in fuel condition
P1141 Fuel restriction indicator circuit Malfunction
P1142 Fuel restriction Condition
P1143 Air assist control valve Range / Performance
P1144 Air assist control valve circuit Malfunction
P1145 Lucas DCN2 - Noise on the needle lift sensor. Incoherence
P1150 Lack of HO2S 21 switching - Adaptive fuel at limit
P1151 Lack of HO2S 21 switching - Sensor indicates lean
P1152 Lack of HO2S 21 switching - Sensor indicated rich
P1153 Bank 2 Fuel control shifted lean. MM6LP - Throttle stop learning. Malfunction
P1154 Bank 2 Fuel control shifted rich
P1155 Alternative fuel controller
P1156 Fuel select switch malfunction
P1157 Lack of HO2S 22 switching - Sensor indicates lean
P1158 Lack of HO2S 22 switching - Sensor indicates rich
P1159 Fuel stepper motor Malfunction
P1164 Fuel pressure sensor test
P1165 SID 803 - Fuel Pressure signal. Pressure change coherence.
P1167 Invalid test throttle not pressed (AL4 - Fault in pressure regulation - variation/recommendation)
P1168 Fuel rail sensor In range low failure
P1169 Fuel rail sensor In range high failure / EDC15C2-Condenser 1 voltage
P1170 Engine shut off (ESO) solenoid Fault / EDC15C2-Condenser 2 voltage
P1171 Rotor sensor Fault / EDC15C2-Engine stop test by injector cut-off
P1172 Rotor control Fault
P1173 Rotor calibration Fault
P1174 Cam sensor Fault
P1175 Cam control Fault
P1176 Cam calibration Fault
P1177 Synchronisation Fault
P1178 (open)
P1180 Fuel delivery system Malfunction - low
P1181 Fuel delivery system Malfunction - high
P1182 Fuel shut off solenoid Malfunction
P1183 Engine oil temperature circuit Malfunction
P1184 Engine oil temperature Out of self test range
P1185 Fuel pump temperature sensor (FTS) high
P1186 Fuel pump temperature sensor (FTS) low
P1187 Varient selection
P1188 Calibration memory fault
P1189 Pump speed signal Fault
P1190 Calibration resistor out of range
P1191 Key line voltage
P1192 Voltage external
P1193 EGR drive Overcurrent
P1194 ECU A/D converter
P1195 SCP HBCC Failed to Inititialise
P1196 Key off voltage high
P1197 Key off voltage low / Piezo-electric injector, power stage
P1198 Pump rotor control Underfuelling - SID801 - Diesel high pressure monitoring. Flow regulator at stop.
P1199 Fuel level Input circuit low
P12XX - Fuel and Air Metering
P1200 Injector control circuit - EDC16C3 Diesel high pressure monitoring. Maximum pressure exceeded.
P1201 Injector circuit open/shorted - cylinder #1
P1202 Injector circuit open/shorted - cylinder #2
P1203 Injector circuit open/shorted - cylinder #3
P1204 Injector circuit open/shorted - cylinder #4
P1205 Injector circuit open/shorted - cylinder #5
P1206 Injector circuit open/shorted - cylinder #6
P1209 Injector control pressure system Fault
P1210 Injector control pressure above expected level
P1211 Injector control pressure sensor above/below desired
P1212 Injector control pressure Not detected during crank
P1213 Start injector circuit Malfunction
P1214 Pedal position sensor B circuit Intermittent
P1215 Pedal position sensor C circuit low input
P1216 Pedal position sensor C circuit high input
P1217 Pedal position sensor C circuit Intermittent
P1218 CID high
P1219 CID low
P1220 Series throttle control system Malfunction
P1221 Traction control system Malfunction
P1222 Traction control output circuit Malfunction
P1223 Pedal demand sensor B circuit high input
P1224 Throttle position sensor B out of self test range
P1225 Needle lift sensor Malfunction
P1226 Control sleeve sensor Malfunction
P1227 Wastegate failed closed (over pressure)
P1228 Wastegate failed open (under pressure)
P1229 Intercooler pump driver Fault
P1230 Fuel pump low speed Malfunction
P1231 Fuel pump secondary circuit low high speed
P1232 Fuel pump primary speed circuit Malfunction
P1233 Fuel pump driver module Off line
P1234 Fuel pump driver module Off line
P1235 Fuel pump control Out of range
P1236 Fuel pump control Out of range
P1237 Fuel pump secondary circuit Malfunction
P1238 Fuel pump secondary circuit Malfunction
P1239 Speed fuel pump position feed Fault
P1240 Sensor power supply Malfunction
P1241 Sensor power supply Low input
P1242 Sensor power supply High input
P1243 Second fuel pump faulty or ground fault
P1244 Alternator load input failed High
P1245 Alternator load input failed Low
P1246 Alternator load input failed
P1247 Turbo boost pressure Low
P1248 Turbo boost pressure not detected
P1249 Wastegate control valve performance
P1250 PRC solenoid circuit Malfunction
P1251 Air mixture solenoid circuit Malfunction
P1252 Pedal correlation PDS1 & LPDS High
P1253 Pedal correlation PDS1 & LPDS Low
P1254 Pedal correlation PDS2 & LPDS High
P1255 Pedal correlation PDS2 & LPDS Low
P1256 Pedal correlation PDS1 & HPDS
P1257 Pedal correlation PDS2 & HPDS
P1258 Pedal correlation PDS1 & PDS2
P1259 Immobiliser to PCM signal error
P1260 Theft detected Vehicle immobilised
P1261 Cylinder #1 High to Low short
P1262 Cylinder #2 High to Low short
P1263 Cylinder #3 High to Low short
P1264 Cylinder #4 High to Low short
P1265 Cylinder #5 High to Low short
P1266 Cylinder #6 High to Low short
P1267 Cylinder #7 High to Low short
P1268 Cylinder #8 High to Low short
P1269 Immobiliser Code not programmed
P1270 Engine RPM or speed limiter reached
P1271 Cylinder #1 High to Low open
P1272 Cylinder #2 High to Low open
P1273 Cylinder #3 High to Low open
P1274 Cylinder #4 High to Low open
P1275 Cylinder #5 High to Low open
P1276 Cylinder #6 High to Low open
P1277 Cylinder #7 High to Low open
P1278 Cylinder #8 High to Low open
P1280 Injection control pressure Out of range Low
P1281 Injection control pressure Out of range High
P1282 Excessive injection control pressure
P1283 IPR circuit failure
P1284 Aborted KOER - ICP failure
P1285 Cylinder head over temp sensed
P1286 Fuel pulse In range but Lower than expected
P1287 Fuel pulse In range but Higher than expected
P1288 Cylinder head temp sensor Out of self test range
P1289 Cylinder head temp sensor High input
P1290 Cylinder head temp sensor Low input
P1291 Injector High side short to GND or VBATT - Bank 1
P1292 Injector High side short to GND or VBATT - Bank 2
P1293 Injector High side open - Bank 1
P1294 Injector High side open - Bank 2/Target idle not reached
P1295 Multi-faults - Bank 1 - with low side shorts
P1296 Multi-faults - Bank 2 - with low side shorts
P1297 Injector high sides shorted together
P1298 IDM failure
P1299 Cylinder head overtemperature protection active
P13XX - Ignition system
P1300 Boost calibration fault
P1301 Boost calibration High
P1302 Boost calibration Low
P1303 EGR calibration fault
P1304 EGR calibration High
P1305 EGR calibration Low
P1306 Kickdown Relay pull - In circuit fault
P1307 Kickdown Relay Hold circuit fault
P1308 A/C clutch circuit fault
P1309 Misfire monitor AICE chip fault
P1313 Misfire rate Caltalyst damage fault - Bank 1
P1314 Misfire rate Catalyst damage fault - Bank 2
P1315 Persistent misfire
P1316 Injector circuit IDM codes detected
P1317 Injector circuit IDM codes not detected
P1327 Ignition - Integrated Phase detection
P1336 Crank/Cam sensor range/performanceME7.4.5. Combustion misfiring on unspecified cylinders.
P1338 ME7.4.5. Cylinder No.2 misfires.
P1340 Camshaft position sensor B circuit Malfunction
P1341 Camshaft position sensor B range/performance
P1345 SGC (cam position) sensor circuit Malfunction / Crankshaft
P1346 Fuel level sensor B circuit Malfunction
P1347 Fuel level sensor B range / performance
P1348 Fuel level sensor B circuit Low
P1349 Fuel level sensor B circuit High
P1350 Fuel level sensor B Intermittent/Bypass line monitor / SID 801 - Pre/Post heating relay circuit - Short or Open circuit, including Pre-Heat plugs
P1351 IDM input circuit Malfunction/Ignition coil control circuit High voltageSID 803 - Pre/Post heating relay circuit. Relay not controlled and glow plugs supplied.
P1352 Ignition coil A Primary circuit Malfunction / SID 801- Pre/Post heating relay circuit - Relay & Pre-Heat plugs not controlled
P1353 Ignition coil B Primary circuit Malfunction
P1354 Ignition coil C Primary circuit Malfunction
P1355 Ignition coil D Primary circuit Malfunction
P1360 Ignition coil A Secondary circuit Malfunction
P1361 Ignition control (IC) circuit Low voltage
P1362 Ignition coil C Secondary circuit Malfunction
P1363 Ignition coil D Secondary circuit Malfunction
P1364 Ignition coil Primary circuit Failure
P1365 Ignition coil Secondary circuit Failure
P1366 Ignition spare
P1367 Ignition spare
P1368 Ignition spare
P1369 Engine temperature light monitor Malfunction
P1370 Insufficient RMP increase during spark test
P1371 Ignition coil - Cylinder #1 - Early activation fault
P1372 Ignition coil - Cylinder #2 - Early activation fault
P1373 Ignition coil - Cylinder #3 - Early activation fault
P1374 Crankshaft position (CKP) / Ignition coil - Cylinder #4 - Early activation fault
P1375 Ignition coil - Cylinder #5 - Early activation fault
P1376 Ignition coil - Cylinder #6 - Early activation fault
P1380 Misfire detected - Rough road date not available
P1381 Variable Cam timing Overadvanced (Bank #1) / Misfire detected no communiction with BCMP1382 Variable Cam timing solenoid #1 circuit Malfunction
P1383 Variable Cam timing Overretarded (Bank #1)
P1384 VVT solenoid A Malfunction
P1385 Variable Cam timing solenoid B Malfunction
P1386 Variable Cam timing Overadvanced (Bank #2)
P1387 Variable Cam timing solenoid #2 circuit Malfunction
P1388 Variable Cam timing Overretarded (Bank #2)
P1389 Glow plug circuit High side Low input
P1390 Octane adjust pin out of self test range
P1391 Glow plug circuit Low input (Bank #1)
P1392 Glow plug circuit High input (Bank #1)
P1393 Glow plug circuit Low input (Bank #2)
P1394 Glow plug circuit High input (Bank #2)
P1395 Glow plug monitor Fault (Bank #1)
P1396 Glow plug monitor Fault (Bank #2)
P1397 System voltage Out of selt test range
P1398 VVT solenoid B circuit High input
P1399 Glow plug circuit High side High input
P14XX - Auxiliary Emission Controls
P1400 DPFE circuit Low input
P1401 DPFE circuit High input
P1402 EGR metering Orifice restricted
P1403 Additional heating circuit 1
P1404 IAT - B circuit Malfunction / EGR closed position performance / EDC15C2-Additional heating circuit 2 and pre-heat
P1405 DPFE sensor upstream Hose off or plugged
P1406 EGR position sensor performance
P1407 EGR No flow detected
P1408 EGR Flow out of selt test range / EDC15C2-Additional heating circuit
P1409 EVR control circuit Malfunction
P1411 SAI system incorrect downstream flow detected / EDC15C2-Converter upstream temperature
P1413 SAI system monitor circuit Low input
P1414 SAI system monitor circuit High input
P1415 Air pump circuit Malfunction / Air system bank 1
P1416 Port air circuit Malfunction / Air system bank 2 / EDC15C2-Converter downstream temperature
P1417 Port air relief circuit Malfunction
P1418 Split air #1 circuit malfunction
P1419 Split air #2 circuit malfunction
P1420 Catalyst temperature sensor failure
P1421 Catalyst damaged
P1422 EGI temperature sensor failure
P1423 EGI functionality test failed
P1424 EGI Glow plug Primary failure
P1425 EGI glow plug Secondary failure / ED15C2 with FAP - Catalytic converter downstream temperature signal. Short circuit to positive or open circuit or Coherence between converter 1 & 2 temperature signal.
P1426 EGI mini MAF failed Out of range
P1427 EGI mini MAF failed Short circuit
P1428 EGI mini MAF failed Open circuit
P1429 Electric air pump Primary failureEDC15C2 Particulate Differential pressure sensor value. Coherence of the differential pressure when stopped.
P1430 Electric air pump Secondary failure
P1433 A/C Refrigerant temperature circuit Low
P1434 A/C Refrigerant temperature circuit High
P1435 A/C Refrigerant temperature circuit Range/Performance / EDC15C2-Additive adding system. Faults additive accuracy.
P1436 A/C Evaporator air temperature circuit Low
P1437 A/C Evaporator air temperature circuit High
P1438 A/C Evaporator air temperature circuit Range/Performance
P1439 Floor temperature switch circuit malfunction
P1440 Purge valve stuck open
P1441 Evaporative emission (EVAP) system flow during non-purge (Oldsmobile / Chevrolet only)P1442 Evaporative emission control system Leak detected / EDC15C2-Quantity of additive Additive ECU.P1443 Evaporative emission control system control valve
P1444 Purge flow sensor circuit Low input
P1445 Purge flow sensor circuit High input
P1446 Evaporative vac solenoid circuit malfunctionEDC15C2-(607) Additive level.(307) Additive quantity. Additive minimum level wait.
P1447 ELC system closure valve Flow faultEDC15C2- PEF filter pierced or differential pressure incorrect.
P1448 ELC system 2 faultEDC15C2 PEF: Particulate emission filter overloaded.
P1449 Evaporative check solenoid circuit malfunction
P1450 Unable to bleed up fuel tank vacuum
P1451 Evaporative emission control system vent control valve circuit
P1452 Unable to bleed Up vacuum in tank
P1453 Fuel tank pressure relief valve malfunction
P1454 Evaporative system vacuum test malfunction
P1455 Evaporative emission control system Leak detected (Gross leak / no flow)
P1456 Fuel tank temperature sensor circuit malfunction
P1457 Unable to pull vacuum in tank
P1458 Coolant solenoid valve Short to earth or open circuit.
P1460 Wide open throttle A/C cutoff relay circuit
P1461 A/C pressure sensor circuit Voltage LowSID 803 - EGR valve. Learning
P1462 A/C pressure sensor circuit Voltage High
P1463 A/C pressure sensor Insufficient pressure change
P1464 A/C demand Out of self test range
P1465 A/C Relay circuit malfunction
P1466 A/C Refrigerant temperature sensor /circuit malfunction
P1467 A/C Compressor temperature sensor malfunction
P1468 SSPOD Open circuit or Closed circuit fault
P1469 Low A/C cycling period
P1470 A/C Cycling period too short
P1471 Electrodrive Fan 1 Operational failure (Driver side)
P1472 Electrodrive Fan 2 Operational failure (Passenger side)
P1473 Fan Secondary High with fans (off)
P1474 Low fan control Primary circuit malfunction
P1475 Fan relay (low) circuit malfunction
P1476 Fan relay (high) circuit malfunction
P1477 Additional fan relay circuit malfunction / EDC15C2-Coolant solenoid valve
P1478 Cooling fan driver fault
P1479 High fan control Primary circuit malfunction / EDC15C2-Coolant solenoid valve
P1480 Fan secondary low with low fan on
P1481 Fan secondary low with high fan on
P1482 SCPP1483 Power to fan circuit Overcurrent
P1484 Open power to ground VCRM
P1485 EGRV circuit malfunction
P1486 EGRA circuit malfunction
P1487 EGRCHK solenoid circuit malfunction
P1490 Secondary Air relief solenoid circuit malfunction
P1491 Secondary switch solenoid circuit malfunction
P1492 APLSOL solenoid circuit malfunction
P1493 RCNT solenoid circuit malfunction
P1494 SPCUT solenoid circuit malfunction
P1495 TCSPL solenoid circuit malfunction
P15XX - Vehicle speed / Idle control and Auxiliary Inputs
P1500 Vehicle speed sensor Intermittent
P1501 Vehicle speed sensor Out of self test range
P1502 Vehicle speed sensor Intermittent malfunction
P1503 Auxiliary speed sensor fault
P1504 Idle air control circuit malfunction
P1505 Idle air control system at adaptive clip
P1506 Idle air control Overspeed error
P1507 Idle air control Underspeed error / EDC15C2-Anti-boiling strategy activated
P1508 Idle control system circuit Open
P1509 Idle control system circuit Shorted
P1510 Idle signal circuit malfunction
P1511 Idle switch (Electronic control Throttle) circuit malfunction / EDC15C2-ECU supplied as +APC
P1512 Intake manifold runner control (Bank 1) Stuck closed
P1513 Intake manifold runner control (Bank 2) Stuck closed
P1514 High load Neutral/Drive fault
P1515 Electric current circuit malfunction
P1516 IMRC Input error (Bank 1)
P1517 IMRC Input error (Bank 2)EDC15C2-Coded anti-start function
P1518 Intake manifold runner control (Stuck open)
P1519 Intake manifold runner control (Stuck closed)
P1520 Intake manifold runner control circuit malfunction
P1521 Variable intake solenoid #1 circuit malfunction / EDC15C2-Clutch sensor
P1522 Variable intake solenoid #2 circuit malfunction
P1523 IVC solenoid circuit malfunction
P1524 Variable intake solenoid system
P1525 Air bypass valve system
P1526 Air bypass system
P1527 Accelerate warmup solenoid circuit malfunction
P1528 Subsidiary Throttle valve solenoid malfunctionP1529 SCAIR solenoid circuit malfunction
P1530 A/C clutch circuit malfunction
P1531 Invalid test - Accelerator pedal movement
P1532 IMCC circuit malfunction Bank B
P1533 AAI circuit malfunction
P1534 Inetia switch activated
P1535 Blower fan speed circuit range/performance
P1536 Parking brake switch circuit failure / EDC15C2-ESP plausibility
P1537 Intake manifold runner control (Bank 1) Stuck openEDC15C2 - Accelerator pedal jammed. Strategy activated.
P1538 Intake manifold runner control (Bank 2) Stuck open
P1539 Power to A/C clutch circuit Overcurrent
P1540 Air bypass valve circuit malfunction
P1543 Air conditioning compressor cut-off circuit
P1549 IMCC circuit malfunction Bank B
P1550 PSPS Out of self test range
P1565 Speed control command switch Out of range High
P1566 Speed control command switch Out of range Low
P1567 Speed control Output circuit continuity
P1568 Speed control Unable to hold speed
P1571 Brake switch malfunction
P1572 Brake pedal switch circuit malfunction
P1573 Throttle position Not available
P1574 Throttle position sensor Disagreement between sensors
P1575 Pedal position Out of self test range
P1576 Pedal position Not available
P1577 Pedal position sensor Disagreement between sensors
P1578 ETC Power less than demand
P1579 ETC In power limiting mode
P1580 Electronic throttle monitor PCM Override
P1581 Electronic throttle monitor malfunction
P1582 Electronic throttle monitor Data available
P1583 Electronic throttle monitor Cruise disable
P1584 TCU detected IPE circuit malfunction
P1585 Throttle control unit malfunction
P1586 Throttle control unit Throttle position malfunction
P1587 Throttle control unit modulated command malfunction
P1588 Throttle control unit detected loss of return spring
P1589 TCU Unable to control desired throttle angle
P16XX - Computer and Auxiliary Outputs
P1600 Loss of Keep alive memory(KAM) power Open circuitP1601 ECM/TCM Serial communication error
P1602 Immobiliser/ECM communication error
P1603 EEPROM malfunction
P1604 Code word Unregistered
P1605 Keep alive memory (KAM) test failure
P1606 ECM control relay O/P circuit malfunction
P1607 MIL O/P circuit malfunction
P1608 Internal ECM malfunction (Bosch system-Control.Coolant temperature alert)
P1609 Diagnostic lamp driver fault
P1610 SBDS Interactive codes
P1611 SBDS Interactive codes
P1612 SBDS Interactive codes
P1613 Configuration
P1614 SBDS Interactive codes
P1615 SBDS Interactive codes
P1616 SBDS Interactive codes
P1617 SBDS Interactive codes
P1618 SBDS Interactive codes
P1619 SBDS Interactive codes
P1620 SBDS Interactive codes
P1621 Control module Long term memory performance / Immobiliser code words Not matched
P1622 Immobiliser ID does not match / System anomaly
P1623 Immobiliser code word / ID number Write failure
P1624 Anti theft system
P1625 B+ supply to VCRM fan circuit malfunction
P1626 Theft deterent fuel enable signal not received / B+ supply to VCRM A/C circuit malfunction
P1627 Module supply voltage Out of range
P1628 Module Ignition supply Input malfunction
P1629 Internal voltage regulator malfunction
P1630 Internal Vref malfunction
P1631 Theft deterent Start enable signal not correct/Main relay malfunction (Power latch)/ Internal ECM fault / Configuration fault)
P1632 Smart alternator faults sensor/circuit malfunction
P1633 KAM voltage too low
P1634 Data Output link circuit failure
P1635 Tyre / Axle ratio Out of acceptable range
P1636 Inductive signiture Chip communication error
P1637 CAN link ECM?ABSCM circuit / network malfunction
P1638 CAN link ECM/INSTM circuit / network malfunction
P1639 Vehicle ID block corrupted or not programmed
P1640 Powertrain DTCs available in another module
P1641 Fuel pump Primary circuit failureSID801 Piezo-electric injector, power stage.
P1642 Fuel pump monitor circuit High input
P1643 Fuel pump monitor circuit Low input
P1644 Fuel pump speed control circuit malfunction
P1645 Fuel pump resistor switch circuit malfunction
P1650 PSP switch Out of self test rangeP1651 PSP switch Input malfunction
P1652 IAC monitor disabled by PSP switch failed on
P1653 Power steering Output circuit malfunctionP1654 Recirculation Override circuit malfunction
P1655 Starter disable circuit malfunction
P1660 Output circuit check signal High
P1661 Output circuit check signal Low
P1662 IDM_EN circuit failure
P1663 Fuel demand command signal circuit malfunction
P1667 CI circuit malfunction
P1668 PCM-IDM communications error
P1670 Electronic feedback signal Not detected
P1680 Metering Oil pump malfunctionP1681 Metering Oil pump malfunction
P1682 Metering Oil pump malfunction
P1683 Metering Oil pump temperature sensor circuit malfunction
P1684 Metering Oil pump position sensor circuit malfunction
P1685 Metering Oil pump stepping motor circuit malfunction
P1686 Metering Oil pump stepping motor circuit malfunction
P1687 Metering Oil pump stepping motor circuit malfunction
P1688 Metering Oil pump stepping motor circuit malfunction
P1689 Oil pressure control solenoid circuit malfunction
P1690 Wastegate solenoid circuit malfunctionP1691 Turbo pressure control solenoid circuit malfunction
P1692 Turbo control solenoid circuit malfunction
P1693 Turbo charge control circuit malfunction - SID 803 Starting and switching off of the engine controlled. Starting or switch-off requests absent or not valid.
P1694 Turbo charge relief circuit malfunctionP17XX - Transmission
P1700 Transmission Indeterminate failure (failed to neutral)
P1701 Reverse engagement error
P1702 TRS circuit Intermittent malfunction
P1703 Brake switch Out of self test range
P1704 Digital TRS failed to transmission states in KOEO / KOER
P1705 Not in P or N during KOEO / KOER
P1706 High vehicle speed observed in Park
P1707 Transfer cas Neutral indicator Hard fault present
P1708 Clutch switch circuit malfunction
P1709 PNP switch Out of self test range
P1711 TFT sensor Out of self test range
P1712 Transmission Torque reduction request signal malfunction
P1713 TFT sensor In range failure Low value
P1714 SSA Inductive signiture malfunction
P1715 SSB Inductive signiture malfunction
P1716 SSC Inductive signiture malfunction
P1717 SSD Inductive signiture malfunction
P1718 TFT sensor In range failure High
P1720 Vehicle speed (meter) circuit malfunction
P1721 Gear 1 Incorrect ratio
P1722 Gear 2 Incorrect ratio
P1723 Gear 3 Incorrect ratioP1724 Gear 4 Incorrect ratio
P1725 Insufficient engine speed increase during self test
P1726 Insufficient engine speed decrease during self test
P1727 Coast clutch solenoid Inductive signiture malfunction
P1728 Transmission slip error
P1729 4x4 Low switch error
P1730 Gear control malfunction 2,3,5
P1731 1-2 Shift malfunction
P1732 2-3 Shift malfunction
P1733 3-4 Shift malfunction
P1734 Gear control malfunction
P1735 First gear switch circuit malfunction
P1736 Second gear switch circuit malfunction
P1737 Lockup solenoid system
P1738 Shift time error
P1739 Slip solenoid system
P1740 Torque converter clutch Inductive signiture malfunction
P1741 Torque converter clutch control error
P1742 Torque converter clutch solenoid failed On
P1743 Torque converter clutch solenoid failed On
P1744 Torque converter clutch system performance
P1745 Line pressure solenoid system
P1746 Pressure control solenoid A Open circuit
P1747 Pressure control solenoid A Short circuit
P1748 EPC malfunction
P1749 Pressure control solenoid failed Low
P1751 Shift solenoid A performance
P1754 Coast clutch solenoid circuit malfunction
P1755 Intermediate speed sensor (ISS) malfunction
P1756 Shift solenoid B performance
P1760 Pressure control solenoid A Short circuit
P1761 Shift solenoid C performance
P1762 Overdrive band failed Off
P1765 Timing solenoid circuit malfunction
P1767 Torque converter clutch circuit malfunction
P1768 Performance / Normal / Winter mode Input malfunction
P1769 AG4 Transmission torque modulation fault
P1770 Clutch solenoid circuit malfunction
P1775 Transmission system MIL fault
P1776 Ignition retard request duration fault
P1777 Ignition retard request circuit fault
P1778 Transmission reverse I/P circuit malfunction
P1779 RCIL circuit malfunction
P1780 Transmission control switch (O/D cancel) Out of self test range
P1781 4x4 switch Out of self test range
P1782 P/ES circuit Out of self test range
P1783 Transmission Over temperature condition
P1784 Transmission mechanical failure-First and Reverse
P1785 Transmission mechanical failure-First and Second
P1786 3-2 Downshift error
P1787 2-1 Downshift error
P1788 Pressure control solenoid B Open circuit
P1789 Pressure control solenoid B Short circuit
P1790 TP (mechanical) circuit failure
P1791 TP (electric) circuit failure
P1792 Barometer pressure circuit malfunction
P1793 Intake air volume circuit malfunction
P1794 Battery voltage circuit malfunction
P1795 Idle switch circuit malfunction
P1796 Kickdown switch circuit malfunction
P1797 Neutral switch circuit malfunction
P1798 Coolant temperature circuit malfunction
P1799 Hold switch circuit malfunction
P18XX - Transmission
P1800 Transmission clutch Interlock safety switch circuit failure
P1801 Transmission clutch Interlock safety switch Open circuit
P1802 Transmission clutch Interlock safety switch short circuit to Battery
P1803 Transmission clutch Interlock safety switch short circuit to ground
P1804 Transmission 4-wheel drive High indicator circuit failure
P1805 Transmission 4-wheel drive High indicator Open circuit
P1806 Transmission 4-wheel drive High indicator short circuit to battery
P1807 Transmission 4-wheel drive High indicator short circuit to ground
P1808 Transmission 4-wheel drive Low indicator circuit failure
P1809 Transmission 4-wheel drive Low indicator Open circuit
P1810 TFP valve position switch circuit / transmission 4-wheel drive Low indicator short circuit to battery
P1811 Transmission 4-wheel drive Low indicator Short to ground
P1812 Transmission 4-wheel drive mode select circuit failure
P1813 Transmission 4-wheel drive mode select Open circuit
P1814 Transmission 4-wheel drive mode select short to battery
P1815 Transmission 4-wheel drive mode select short to ground
P1816 Transmission Neutral safety switch circuit failure
P1817 Transmission Neutral safety switch Open circuitP1818 Transmission Neutral safety switch Short circuit to battery
P1819 Transmission Neutral safety switch Short circuit to ground
P1820 Transmission transfer case clockwise shift relay coil circuit failure
P1821 Transmission transfer case clockwise shift relay coil Open circuit
P1822 Transmission transfer case clockwise shift relay coil Short circuit to battery
P1823 Transmission transfer case clockwise shift relay coil Short circuit to ground
P1824 Transmission 4-wheel drive clutch relay circuit failure
P1825 Transmission 4-wheel drive clutch relay Open circuit
P1826 Transmission 4-wheel Low clutch relay circuit to battery
P1827 Transmission 4-wheel Low clutch relay circuit to ground
P1828 Transmission transfer case counter clockwise shift relay coil circuit failure
P1829 Transmission transfer case counter clockwise shift relay coil Open circuit
P1830 Transmission transfer case counter clockwise shift relay coil short circuit to battery
P1831 Transmission transfer case counter clockwise shift relay coil short circuit to ground
P1832 Transmission transfer case differetial lockup solenoid circuit failure
P1833 Transmission transfer case differetial lockup solenoid Open circuit
P1834 Transmission transfer case differetial lockup solenoid short circuit to battery
P1835 Transmission transfer case differetial lockup solenoid short circuit to ground
P1836 Transmission transfer case front shaft speed sensor circuit failure
P1837 Transmission transfer case rear shaft speed sensor circuit failure
P1838 Transmission transfer case shift motor circuit failure
P1839 Transmission transfer case shift motor Open circuit
P1840 Transmission transfer case shift motor short circuit to battery
P1841 Transmission transfer case shift motor short circuit to ground
P1842 Transmision transfer case differential lockup feedback switch circuit failure
P1843 Transmision transfer case differential lockup feedback switch Open circuit
P1844 Transmision transfer case differential lockup feedback switch short circuit to battery
P1845 Transmision transfer case differential lockup feedback switch short circuit to ground
P1846 Transmission transfer case contact plate A circuit failure
P1847 Transmission transfer case contact plate A Open circuit
P1848 Transmission transfer case contact plate A Short circuit to battery
P1849 Transmission transfer case contact plate A short circuit to ground
P1850 Transmission transfer case contact plate B circuit failure
P1851 Transmission transfer case contact plate B Open circuit
P1852 Transmission transfer case contact plate B Short circuit to battery
P1853 Transmission transfer case contact plate B Short circuit to ground
P1854 Transmission transfer case contact plate C circuit failure
P1855 Transmission transfer case contact plate C Open circuit
P1856 Transmission transfer case contact plate C Short circuit to battery
P1857 Transmission transfer case contact plate C Short circuit to ground
P1858 Transmission transfer case contact plate D circuit failure
P1859 Transmission transfer case contact plate C Open circuit
P1860 TCC PWM solenoid circuit electrical / transmission transfer case contact plate D Short circuit to battery
P1861 Transmission transfer case contact plate D Short circuit to ground
P1862 Transmission transfer case contact plate power circuit failure
P1863 Transmission transfer case contact plate power Open circuit
P1864 Transmission transfer case contact plate power Short circuit to battery
P1865 Transmission transfer case contact plate power Short circuit to ground
P1866 Transmission transfer case system concern - Setting required
P1867 Transmission transfer case contact plate General circuit failure
P1868 Transmission automatic 4-wheel drive indicator lamp circuit failure
P1869 Transmission automatic 4-wheel drive indicator lamp circuit Short to battery
P1870 Tansmission component slipping/Transmission mechanicl transfer case 4x4 switch circuit malfunction
P1871 Transmission mechanical transfer case 4x4 switch circuit Short to battery
P1872 Transmission mechanical 4-wheel drive Axle lock lamp circuit failure
P1873 Transmission mechanical 4-wheel drive Axle lock lamp circuit Short to battery
P1874 Transmission automatic hall effect sensor power circuit failure
P1875 Transmission automatic hall effect sensor power circuit Short to battery / 4wd Low switch circuit electrical
P1876 Transmission transfer case 2-wheel drive solenoid circuit failure
P1877 Transmission transfer case 2-wheel drive solenoid circuit Short to battery
P1878 Transmission transfer case disengaged solenoid circuit failure
P1879 Transmission transfer case disengaged solenoid Open circuit
P1880 Transmission transfer case disengaged solenoid short to battery
P1881 Engine coolant level switch circuit failure GEM
P1882 Engine coolant level switch circuit Short to ground
P1883 Engine coolant level switch circuit failure GEM
P1884 Engine coolant level lamp circuit Short to ground
P1885 Transmission transfer case disengaged solenoid Short to ground
P1886 4x4 Initialisation failure
P1890 Transmission 4wd mode select return input circuit failure
P1891 Transmission transfer case contact plate ground return Open circuit
P19XX - Transmission
P1900 OSS circuit intermittent malfunction
P1901 TSS circuit intermittent malfunction
P1902 Pressure control solenoid B intermittent short
P1903 Pressure control solenoid C Short circuit
P1904 Pressure control solenoid C Open circuit
P1905 Pressure control solenoid C Intermittent short
P1906 Kickdown pull relay Open or Short circuit to ground
P1907 Kickdown hold relay Open or Short circuit to ground
P1908 Transmission pressure circuit solenoid Open or Short to ground
P1909 Transmission temperature sensor circuit Open or Short to power or ground
P1910 VFS A pressure Output failed Low
P1911 VFS B pressure Output failed Low
P1912 VFS C pressure Output failed Low
P1913 Pressure switch A circuit malfunction
P1914 Manually shifted automatic (MSA) switch circuit malfunction
P1915 Reverse switch circuit malfunction
P1916 High clutch drum speed sensor malfunction
P1917 High clutch drum speed sensor Intermittent
P1918 Transmission range display circuit malfunction
P2002 Particulate emission filter
P2021 CAN engine torque information. No signal
P2025 Engine speed signal. No signal
P2120 Intake air heating circuit
P2144 EGR valve
P2263 Multifunction switch signal fault. Intermediate position
P2299 Accelerator pedal blockedP2408 EDC16C3 - Additive system. Fuel tank cap presence sensor.
P2562 SID 803.Turbo pressure solenoid valve. Valve position too distant in relation to reference value, (repeat value for turbo incorrect)
P2563 SID 803.Turbo pressure solenoid valve. Valve position too distant in relation to reference value, (repeat value for turbo incorrect)
P3004 3rd piston de-activator
Merci à qashqai-passion U.K :wink: :wink:
Fred21
Re: codes défauts Nissan qashqai
Messagepar Fred21 » Lun Nov 30, 2015 10:31
Houlala tous les défauts possibles, c'est pas bon signe :mrgreen:
QASQHAI Connect Edition 1.5 dci de 2015
Elio
Messagepar Elio » Lun Nov 30, 2015 14:59
Merci Titou
j'espère ne pas les voir...
mais au cas où...
Messagepar bino94320 » Lun Nov 30, 2015 18:48
ca c'est super cette liste, faut la mettre en post-it :wink:
franck3
Messagepar franck3 » Jeu Juin 02, 2016 17:10
liste traduite en français "avec la fonction traduction du PC"
instantanée Nissan Trouble Codes spécifiques Code Description
P1105 MAP / BARO Pressostat électrovanne
P1126 Thermostat Fonction de contrôle Swirl
P1130 Valve Control Solenoid Valve
p1148 Commande à boucle fermée (Banque 1)
P1165 Swirl Contrôle Valve Interrupteur à vide
P1168 Commande à boucle fermée (Banque 2)
P1320 Ignition signal
P1211 ABS / TCS Unité
P1212 ABS / TCS Communication ligne
P1217 moteur surchauffe (surchauffe)
P1335 vilebrequin Capteur de position (REF)
P1336 vilebrequin Capteur de position (CKPS)
P1400 EGRC Electrovanne
P1401 EGR Capteur de température
p1402 système EGR
P1440 EVAP système de contrôle de petite fuite
p1441 Vacuum Cut Valve Bypass Valve
P1444 Canister purge contrôle du volume Electrovanne
P1445 EVAP Canister purge Volume Valve Control
P1446 EVAP traîneau Vent Control Valve (fermé)
P1447 contrôle EVAP système de débit de purge de surveillance
P1448 EVAP traîneau Vent Control Valve (Open)
P1464 Niveau de carburant du circuit du capteur (Rez -de- signal)
P1490 Vacuum Cut Valve clapet de dérivation (Circuit)
P1492 EVAP Bidon de commande de purge / électrovanne (Circuit)
P1493 EVAP Canister purge Control Valve / électrovanne
P1550 TCC Electrovanne
P1605 A / T diagnostic Communication ligne
P1705 Throttle Position Sensor Circuit A / T
P1706 Parc / Position neutre (PNP) Commutateur
P1760 Overrun embrayage Electrovanne (Circuit)
P1003 EDC15C2 - Une intervention extérieure sur le flux. Information automatique de la fonction de boîte de vitesses; valeur reçue incorrecte
P1100 MAF (Mass Air Flow) Capteur intermittent / Systèmes vérifier pas complète capteur
P1101 MAF (Mass Air Flow) Hors de portée d'auto - test
P1102 MAF (Mass Air Flow) capteur dans la gamme , mais inférieur que prévu
P1103 MAF (débit d' air massique ) capteur dans la gamme , mais plus élevé que prévu
P1104 MAF (Mass Air Flow) sol dysfonctionnement
P1105 double défaut alternateur supérieure
P1106 double alternateur inférieure défaut / MAP (Manifold pression absolue) du circuit de capteur intermittent haute tension
P1107 double alternateur circuit inférieur dysfonctionnement / MAP (Manifold Absolute Pression) circuit capteur intermittent basse tension (électrovanne EDC15C2-Swirl)
P1108 double alternateur lampe de batterie circuit dysfonctionnement / Baro MAP (comparaison du collecteur de pression absolue) du capteur trop élevé. EDC15C2 - Fan circuit à haute vitesse. Circuit ouvert ou court - circuit à la terre.
P1109 Intake température de l' air (IAT) capteur B intermittent
P1110 Intake température de l' air (IAT) capteur (D / C) d' ouverture / short.S2000 - Adaptation de la quantité d'air entrant dans le collecteur. EDC15C2 - circuit de coupure climatisation. Circuit ouvert ou court - circuit à la terre.
P1111 température d'air d' admission (IAT) circuit capteur intermittent haute tension
P1112 température d'air d' admission (IAT) Circuit de capteur basse tension intermittente température de l' air d'admission de
P1113 (IAT) circuit de capteur d' ouverture / short moteur
P1114 température du liquide de refroidissement (ECT ) circuit capteur intermittent basse tension / IAT - circuit du capteur B entrée basse température du liquide de refroidissement
p1115 moteur (ECT) capteur circuit haute tension intermittent / IAT - circuit capteur B entrée haute température du liquide de refroidissement
P1116 moteur (ECT) capteur hors plage température
P1117 moteur du liquide de refroidissement ( ECT) circuit capteur intermittent
P1118 Manifold température absolue circuit capteur entrée basse
P1119 Manifold température absolue circuit capteur entrée haute
P1120 Throttle capteur de position (TPS) hors de portée
P1121 Throttle capteur de position (TPS) circuit haute tension intermittent
P1122 Throttle capteur de position (TPS) circuit intermittent basse tension
P1123 Throttle capteur de position (TPS) Dans la gamme , mais plus élevé que prévu capteur de position
P1124 de papillon (TPS) Hors gamme auto - test
P1125 Throttle capteur de position (TPS) circuit intermittent
P1126 Throttle capteur de position (TPS) circuit (Narrow gamme) Dysfonctionnement
P1127 échappement pas sonde à oxygène aval chaud
P1128 amont du capteur d'oxygène chauffé (HO2S) Swapped capteur (HO2S) Swapped de
P1129 en aval de l' oxygène chauffé
P1130 Manque de HO2S commutation - carburant Adaptive à la limite
P1131 Manque de HO2S commutation - capteur indique maigre
P1132 Manque de HO2S commutation - capteur indiqué des températures de convertisseur riche / EDC15C2-catalytiques
P1133 HO2S 1 insuffisant commutation
P1134 HO2S rapport de temps 1 transition circuit de capteur de position
P1135 Pedal Un intermittent circuit de commande
P1136 Fan Dysfonctionnement
p1137 Manque de HO2S 2 switching - capteur indique maigre
P1138 haute pression défaut du capteur de rail / Manque d'HO2S 2 switching - Capteur indique riche
P1139 eau dans le circuit indicateur de carburant Dysfonctionnement
P1140 eau en état ​​de carburant
P1141 carburant indicateur de restriction circuit Dysfonctionnement restriction
P1142 Fuel Condition
P1143 Air aider Plage de soupape de commande / Performance
P1144 Air aider circuit de vanne de commande Dysfonctionnement
p1145 Lucas DCN2 - bruit le capteur de levée d'aiguille. Incohérence
P1150 Manque de HO2S 21 commutation - carburant à la limite Adaptive
P1151 Manque de HO2S 21 commutation - capteur indique maigre
P1152 Manque de HO2S 21 commutation - Capteur indiqué riche
P1153 Bank contrôle 2 de carburant déplacé maigre. MM6LP - l' apprentissage d'arrêt des gaz. Dysfonctionnement
P1154 Bank 2 Contrôle de carburant déplacé riche
P1155 Alternative contrôleur de carburant
P1156 sélecteur de carburant dysfonctionnement
P1157 Manque de HO2S 22 commutation - capteur indique maigre
P1158 Manque de HO2S 22 commutation - capteur indique riche moteur
P1159 pas à pas de carburant Dysfonctionnement
P1164 carburant test du capteur de pression
P1165 SID 803 - signal de pression de carburant. . Changement de pression cohérence
P1167 Invalid gaz d'essai pas enfoncé (AL4 - Défaut dans la régulation de la pression - variation / recommandation) capteur de rail
P1168 de carburant Dans la gamme basse panne capteur de rail
P1169 carburant Dans la gamme haute panne / EDC15C2-condenseur 1 tension
P1170 moteur coupé (ESO ) défaut électrovanne / EDC15C2-condenseur 2 tension
P1171 Rotor capteur défaut / EDC15C2-Engine test d'arrêt par injection de coupure
P1172 Rotor commande Fault
P1174 Cam capteur Fault
P1175 Cam commande Fault
P1177 Synchronisation défaut
P1178 (ouverte )
P1180 système de distribution de carburant Dysfonctionnement - bas Dysfonctionnement
P1181 du système d'alimentation en carburant - haute
P1182 carburant coupé solénoïde Dysfonctionnement circuit de température
P1183 d'huile moteur Anomalie température
P1184 huile moteur hors auto - test gamme haute capteur
P1185 carburant température de la pompe (FTS) du capteur de température de la pompe à carburant
P1186 (FTS) à faible sélection
P1187 Varient
P1188 Calibration défaut mémoire signal de vitesse de la pompe
P1189 défaut de résistance
p1190 Etalonnage hors plage
P1191 Key tension de ligne
P1192 tension externe
p1193 EGR entraînement surintensité
P1194 ECU convertisseur A / D
P1195 SCP HBCC Échec de Inititialise
P1196 Key hors tension élevée
P1197 Key off basse tension piézo-électrique injecteur /, l' étage de puissance de la pompe
P1198 commande du rotor Underfuelling - SID801 - Diesel surveillance haute pression. Régulateur de débit à l' arrêt. Niveau de carburant
P1199 Circuit d'entrée faible
P12xx - carburant et Air Metering
P1200 circuit de commande de Injector - EDC16C3 Diesel surveillance haute pression. Pression maximale dépassée. Circuit
P1201 Injector ouvert court - circuité / - cylindre n ° 1
P1202 Injector circuit ouvert court - circuité / - cylindre n ° 2
P1203 Injector circuit ouvert court - circuité / - cylindre n ° 3
P1204 Injector circuit ouvert court - circuité / - cylindre n ° 4 circuit
P1205 Injector ouvert / court - circuité - cylindre n ° 5
P1206 Injector circuit ouvert court - circuité / - cylindre # 6 système de pression de commande
P1209 Injector Fault P1210 pression de commande d'injection au dessus du niveau attendu capteur de pression
P1211 de contrôle d'injection ci - dessus / au- dessous souhaitée pression de commande d'injection de
P1212 Non détecté lors de manivelle
P1213 Début circuit d'injection Dysfonctionnement
P1214 circuit capteur B de position de la pédale intermittent
P1215 circuit de capteur de position de la pédale de C faible entrée circuit C du capteur de position de la pédale de
P1216 haute entrée position
P1217 Pedal circuit capteur C intermittent
P1218 CID haute
p1219 CID bas système de contrôle des gaz
P1220 Série Anomalie système de contrôle
P1221 traction Dysfonctionnement sortie de commande
p1222 traction circuit Dysfonctionnement
P1223 capteur de demande de pédale circuit B haute entrée capteur de position
P1224 Throttle B hors de soi plage essai capteur aiguille de levage
P1225 Dysfonctionnement capteur de manchon de commande
p1226 Dysfonctionnement
P1227 Wastegate n'a fermé (plus de pression)
P1228 Wastegate n'a pas ouvert (sous pression)
P1229 Intercooler pilote de pompe Défaut
P1230 pompe à carburant basse vitesse Dysfonctionnement pompe
p1231 carburant circuit secondaire à faible vitesse élevée pompe
P1232 carburant circuit de vitesse primaire Anomalie module pilote
P1233 de la pompe à carburant hors ligne
P1234 pompe à carburant module pilote hors ligne commande
p1235 de la pompe à carburant hors de portée de contrôle
P1236 de la pompe à carburant Hors de portée
P1237 pompe à carburant circuit secondaire Dysfonctionnement
P1238 pompe à carburant circuit secondaire Dysfonctionnement position de la pompe à carburant
P1239 Vitesse feed Fault puissance
P1240 alimentation capteur Anomalie
P1241 Capteur alimentation basse entrée capteur
P1242 alimentation entrée haute
P1243 deuxième pompe à carburant défectueux ou défaut de terre Alternateur entrée de charge
p1244 échoué haut
p1245 Alternateur entrée de charge n'a pas faible entrée de charge
P1246 Alternateur n'a pas la pression de suralimentation
p1247 Turbo Low pression de suralimentation
p1248 Turbo non détecté
P1249 Wastegate contrôle des performances de la vanne circuit de solénoïde
P1250 PRC Dysfonctionnement mélange
P1251 Air solénoïde circuit Dysfonctionnement
P1252 Pédale corrélation PDS1 & SDSFP Haute
P1253 Pedal corrélation PDS1 & SDSFP Low
P1254 Pedal corrélation PDS2 & SDSFP Haute
p1255 Pedal corrélation PDS2 & SDSFP Low
P1256 Pedal corrélation PDS1 & HPDS
P1257 Pédale corrélation PDS2 & HPDS
P1258 Pédale corrélation PDS1 & PDS2
P1259 antidémarrage au signal PCM erreur
P1260 vol détecté véhicule immobilisé
P1261 Cylindre # 1 haut au plus bas à court
p1262 Cylindre # 2 élevé au plus bas à court
p1263 Cylindre # 3 élevé au plus bas à court
p1264 Cylindre # 4 élevé au plus bas à court
P1265 Cylindre # 5 élevé au plus bas à court
P1266 Cylindre # 6 élevé au plus bas à court
P1267 Cylindre # 7 élevé au plus bas court
P1268 Cylindre # 8 élevé au plus bas à court
p1269 code antidémarrage pas programmé RPM
P1270 moteur ou limiteur de vitesse atteint
P1271 Cylindre # 1 élevé au plus bas ouvert
p1272 Cylindre # 2 élevé au plus bas ouvert
P1273 Cylindre # 3 élevé au plus bas ouvert
P1274 Cylindre # 4 haut au plus bas ouvert
P1275 Cylindre # 5 élevé au plus bas ouvert
P1276 Cylindre # 6 élevé au plus bas ouvert
P1277 Cylindre # 7 élevé au plus bas ouvert
p1278 Cylindre # 8 élevé au plus bas ouvert pression de commande d'injection
P1280 Hors gamme basse pression de commande d'injection
P1281 Hors de portée Haute
P1282 pression de commande d'injection excessive
P1283 DPI défaillance du circuit
P1284 Aborted KOER - échec ICP
p1285 culasse sur température détectée impulsion
P1286 carburant Dans la gamme , mais plus faible que prévu impulsion
p1287 de carburant Dans la gamme , mais plus élevé que prévu capteur
P1288 culasse temp Hors de la plage d'auto - test
P1289 Cylinder tête de capteur de température d' entrée haute
P1290 Cylinder tête de capteur de température basse entrée
P1291 Injector haut côté court à GND ou VBATT - Banque 1
P1292 Injector côté haut court à GND ou VBATT - Banque 2
P1293 Injector haut côté ouvert - Banque 1
p1294 Injector haut côté ouvertes - Bank 2 / Target IDLE pas atteint
p1295 multi-défauts - Banque 1 - avec un short de côté bas
p1296 multi-défauts - Banque 2 - avec un short de côté bas
P1297 Injector côtés élevés en court - circuit échec IDM
P1299 Cylinder protection tête de surchauffe actif
P13XX - système d'allumage calibration Boost défaut
P1300 calibration Boost P1301 haute calibration Boost
P1302 Low P1303 calibration EGR défaut calibration EGR
P1304 haute calibration P1305 EGR basse traction
P1306 Rétrocontact Relay - Dans le circuit défaut
P1307 Rétrocontact relais Tenir défaut du circuit
P1308 A / C circuit d'embrayage faute moniteur
P1309 de Misfire AICE puce défaut taux
P1313 de Misfire Caltalyst dommages défaut - Banque 1
P1314 Misfire dégâts de catalyseur de taux de défaut - Banque 2
P1315 ratés persistants
P1316 Injector codes IDM du circuit détecté
p1317 Injector codes IDM circuit non détecté
P1327 Ignition - détection de phase intégré gamme
P1336 manivelle capteur / Cam / performanceME7.4.5. Combustion ratés sur les bouteilles non précisées.
P1338 ME7.4.5. Ratés Cylindre No.2. Circuit B du capteur de position
P1340 Camshaft Dysfonctionnement
P1341 Camshaft gamme capteur de position B / performances
P1345 SGC (position de came) / Vilebrequin circuit capteur Anomalie
P1346 carburant circuit capteur de niveau B Dysfonctionnement
P1347 carburant Capteur de niveau gamme B / performances niveau
P1348 de carburant circuit capteur B faible capteur de niveau
P1349 de carburant circuit B High
P1350 capteur de niveau de carburant B intermittent / ligne de Bypass moniteur / SID 801 - Pre / post circuit de chauffage de relais - court - circuit ou ouvert, y compris Pre-Heat branche IDM
P1351 circuit d'entrée Dysfonctionnement bobine / d'allumage circuit de commande haute voltageSID 803 - Pre / post circuit de chauffage de relais. . Relais non contrôlé et les bougies de préchauffage fourni
P1352 Bobine d' allumage A Dysfonctionnement du circuit primaire / SID 801- Pre / Post circuit de chauffage de relais - Relais & Pre-Heat bouchons non contrôlée
P1353 Bobine d' allumage B primaire circuit Dysfonctionnement
P1354 Bobine d' allumage C circuit primaire Dysfonctionnement
P1355 Ignition bobine D primaire circuit Dysfonctionnement
P1360 bobine d' allumage Un circuit secondaire Dysfonctionnement commande
P1361 Ignition (IC) circuit basse tension
P1362 bobine d' allumage C secondaire circuit Dysfonctionnement
P1363 bobine d' allumage D secondaire circuit Dysfonctionnement
P1364 bobine d' allumage primaire circuit non -
P1365 bobine d' allumage Panne de circuit secondaire de rechange
P1366 Ignition
P1367 Ignition épargner
P1368 allumage de rechange
P1369 Engine température moniteur de lumière Dysfonctionnement
P1370 augmentation RMP insuffisante lors de l' essai d'allumage bobine
P1371 Ignition - Cylindre # 1 - faute d'activation précoce bobine
P1372 Ignition - Cylindre # 2 - début défaut d'activation de la bobine
P1373 Ignition - Cylindre # 3 - début faute d'activation poste
P1374 vilebrequin (CKP) / bobine d'allumage - cylindre n ° 4 - faute d'activation précoce bobine
P1375 Ignition - Cylindre # 5 - défaut d'activation précoce bobine
P1376 Ignition - Cylindre # 6 - défaut d'activation précoce
P1380 Misfire détectée - Irrégulier date de route non disponible
P1381 Calage variable Overadvanced (Banque n ° 1) / Misfire n'a détecté aucune communiction avec BCM
P1382 ​​variable Cam timing solénoïde # 1 circuit Dysfonctionnement
P1383 Calage variable Overretarded (Banque n ° 1)
P1384 VVT solénoïde A Dysfonctionnement
P1385 Calage variable solénoïde B Dysfonctionnement
P1386 variable Cam synchronisation Overadvanced (Banque n ° 2)
P1387 Calage variable solénoïde # 2 circuit Dysfonctionnement
P1388 Calage variable Overretarded (Banque n ° 2) fiche circuit
P1389 Glow côté High Low entrée
P1390 Octane ajuster la broche hors de la plage d'auto - test
P1391 bougie de préchauffage circuit basse entrée ( Banque n ° 1)
P1392 Glow circuit de prise d' entrée haute (Banque n ° 1) brancher circuit entrée basse (Banque n ° 2)
P1393 Glow Plug circuit entrée haute (Banque # 2)
P1394 Glow
P1395 bougie de préchauffage moniteur de défaut (Banque n ° 1) fiche
P1396 Glow surveiller Fault (Banque n ° 2) tension du système
P1397 Out of selt plage de test
P1398 VVT électrovanne circuit B entrée haute
P1399 Glow circuit de prise de haut côté entrée élevée
P14XX - auxiliaire Emission Controls P1400 DPFE circuit basse entrée
P1401 DPFE circuit haute entrée p1402 EGR dosage orifice restreint
P1403 circuit de chauffage additionnel 1
p1404 IAT - B circuit Dysfonctionnement / EGR fermé performances de position / circuit de chauffage de EDC15C2-complémentaires 2 et pré-chaleur capteur
P1405 de DPFE Hose amont hors tension ou branché
P1406 EGR capteur de position performances
p1407 EGR Aucun débit détecté
P1408 EGR débit sur plage de test selt / circuit de chauffage EDC15C2-additionnel circuit de commande
P1409 EVR Dysfonctionnement système
P1411 SAI flux aval incorrect détecté / EDC15C2-Converter amont température circuit de contrôle du système de SAI
P1413 Low entrée
p1414 SAI circuit de surveillance du système de haute entrée
P1415 Air circuit de pompe Dysfonctionnement / Air banque de système 1
P1416 Port circuit d'air dysfonctionnement banque système / air 2 / EDC15C2-Converter température en aval circuit de décharge d'air
p1417 Port dysfonctionnement
p1418 de Split air # 1 circuit dysfonctionnement
P1419 de Split air # 2 circuit dysfonctionnement défaillance du capteur de température
p1420 Catalyst p1421 Catalyst endommagé défaillance du capteur de température
P1422 EGI
p1423 EGI test de fonctionnalité échoué
P1424 EGI bougie de préchauffage échec primaire
P1425 EGI bougie de préchauffage secondaire échec / ED15C2 avec FAP - convertisseur catalytique signal de température en aval. Court - circuit à circuit positif ou ouvert ou la cohérence entre le convertisseur 1 & 2 signal de température.
P1426 EGI mini - MAF échoué Hors gamme
P1427 EGI mini - CRG n'a pas court - circuit
P1428 EGI mini - MAF échoué Circuit ouvert
P1429 électrique pompe à air failureEDC15C2 primaire Particules Différentiel valeur de capteur de pression . Cohérence de la pression différentielle à l'arrêt. Pompe à air
p1430 électrique échec secondaire circuit
P1433 A / C de la température du fluide frigorigène à faible circuit de température
p1434 A / C Réfrigérant haut du système en ajoutant
p1435 A / C de la température du fluide frigorigène Plage de circuit / Performance / EDC15C2-Additive. Défauts additives précision.
P1436 A / C Evaporateur circuit de température de l' air à faible
p1437 A / C Evaporateur circuit de température de l' air à haute
P1438 A / C Evaporateur circuit de température de l' air Plage / rendement
P1439 étage commutateur de température dysfonctionnement du circuit vanne
P1440 Purge bloquée en position ouverte émission
p1441 évaporatif (EVAP) le débit du système lors de non-purge (Oldsmobile / Chevrolet uniquement)
P1442 Evaporatoire système de contrôle des émissions de fuite détectée / EDC15C2-Quantité d'additif additif ECU.
P1443 Evaporatoire contrôle des émissions valve de contrôle du système circuit de capteur de débit de purge de
P1444 entrée basse flux de purge de
P1445 circuit capteur haute entrée
P1446 Evaporatoire circuit vac solénoïde malfunctionEDC15C2- (607) Additif de niveau. (307) Additif de quantité. . Additif niveau minimum attente
P1447 ELC clapet de fermeture du système de débit faultEDC15C2- PEF filtre percé ou pression différentielle incorrect.
P1448 ELC système 2 faultEDC15C2 PEF: Filtre à particules d'émission surchargé.
P1449 Evaporatoire contrôle solénoïde dysfonctionnement du circuit
P1450 Impossible de saigner jusqu'à vide du réservoir de carburant
P1451 Evaporatoire émission système de contrôle de ventilation vanne de régulation circuit p1452 Impossible de purger Up vide dans le réservoir
P1453 réservoir de carburant de surpression dysfonctionnement de la valve
P1454 évaporation sous vide du système dysfonctionnement d'essai du système de contrôle des émissions
P1455 Evaporatoire fuite détectée (fuite brute / pas de débit)
P1456 carburant température du réservoir capteur circuit dysfonctionnement
P1457 Impossible pour tirer le vide dans le réservoir .
P1458 Coolant électrovanne court à la terre ou circuit ouvert
p1460 large circuit ouvert papillon A / C coupure du relais
p1461 A / C capteur de pression circuit tension LowSID 803 - vanne EGR. Apprendre
p1462 Un capteur de pression circuit haute tension / C
p1463 capteur de pression A / C variation de pression insuffisante
P1464 A la demande / C Sur auto plage essai
p1465 A / C Relais dysfonctionnement du circuit
P1466 A / C capteur de température de réfrigérant / circuit dysfonctionnement
P1467 A / C Compresseur dysfonctionnement du capteur de température
P1468 SSPOD circuit ouvert ou circuit fermé faute
P1469 Low A / C période de cyclisme période
p1470 A / C cyclisme trop courte
P1471 ElectroDrive Fan 1 échec opérationnel (côté conducteur)
p1472 ElectroDrive Fan 2 échec opérationnel (côté passager)
P1473 Ventilateur secondaire haut avec les fans (off)
P1474 low Fan Control dysfonctionnement du circuit primaire relais
P1475 ventilateur (bas) mauvais fonctionnement du circuit
P1476 relais de ventilateur (haut) mauvais fonctionnement du circuit vanne
P1477 supplémentaires circuit ventilateur de relais de défaut / EDC15C2-Coolant solénoïde
P1478 pilote ventilateur défaut de refroidissement
P1479 commande de ventilation élevée dysfonctionnement du circuit primaire / EDC15C2-Coolant électrovanne
P1480 ventilateur de dépression secondaire à faible fan sur
P1481 ventilateur bas secondaire avec une grande fan sur
P1482 SCP
P1483 puissance au circuit du ventilateur surintensité
P1484 Ouvrir le pouvoir à la terre VCRM
P1485 EGRV circuit dysfonctionnement
P1486 EGRA dysfonctionnement du circuit circuit
P1487 EGRCHK solénoïde dysfonctionnement
P1490 circuit de solénoïde de décharge d'air secondaire dysfonctionnement
P1491 secondaire interrupteur magnétique dysfonctionnement du circuit circuit
P1492 APLSOL électrovanne dysfonctionnement
P1493 RCNT électrovanne dysfonctionnement du circuit
P1494 SPCUT circuit de solénoïde dysfonctionnement
p1495 TCSPL dysfonctionnement du circuit de solénoïde
P15XX - vitesse du véhicule / commande de ralenti et les entrées auxiliaires capteur de vitesse
P1500 véhicule intermittent
P1501 capteur de vitesse du véhicule hors de l' auto plage de test capteur de vitesse intermittente dysfonctionnement
P1502 véhicule
P1503 défaut capteur de vitesse auxiliaire
P1504 dysfonctionnement circuit de commande de l' air de ralenti système
P 1505 de contrôle de l' air de ralenti à adaptatif Clip
P1506 Idle contrôle aérien survitesse erreur
P1507 contrôle de l' air de ralenti erreur Sous -vitesse / EDC15C2-Anti- stratégie d' ébullition activé
P1508 circuit de système ouvert de contrôle de ralenti
P1509 circuit du système de commande de ralenti Shorted
P1510 circuit de signal Idle dysfonctionnement
P1511 contacteur de ralenti (Throttle de commande électronique) dysfonctionnement du circuit / EDC15C2-ECU fourni en + APC
p1512 collecteur d' admission contrôle de coureur (Banque 1) Collé fermé
p1513 collecteur d' admission contrôle de coureur (Banque 2) Collé fermé
P1514 haute charge neutre / défaut variateur
P1515 électrique dysfonctionnement du circuit
P1516 IMRC erreur d'entrée (Banque 1)
P1517 IMRC erreur d'entrée (Banque 2) anti-démarrage fonction EDC15C2-Coded
P1518 Intake collecteur de commande de coureur (Collé ouvert)
P1519 Intake contrôle de collecteur à canaux (Collé fermé)
P1520 collecteur d' admission contrôle de coureur dysfonctionnement du circuit
p1521 admission variable électrovanne # 1 circuit dysfonctionnement / capteur EDC15C2-Clutch
p1522 admission variable électrovanne # 2 circuit dysfonctionnement
p1523 IVC circuit électrovanne dysfonctionnement
p1524 électrovanne d'admission variable système
p1525 Air système de vanne de dérivation système de dérivation
P1526 Air
P1527 Accelerate échauffement électrovanne dysfonctionnement du circuit vanne de papillon
p1528 subsidiaire solénoïde malfunction
P1529 SCAIR circuit électrovanne dysfonctionnement
P1530 ​​A / C circuit d'embrayage dysfonctionnement
P1531 essai non valide - accélérateur mouvement de la pédale
p1532 IMCC circuit dysfonctionnement Banque B
P1533 AAI circuit dysfonctionnement interrupteur
P1534 Inetia activé
P1535 Blower plage de circuit / performances vitesse du ventilateur
P1536 Parking interrupteur de frein panne de circuit / EDC15C2-ESP plausibilité
P1537 Intake contrôle de collecteur à canaux (Banque 1) openEDC15C2 Stuck - pédale d'accélérateur coincé. Stratégie activée.
P1538 Intake contrôle de collecteur à canaux (Banque 2) Collé ouvert Puissance
P1539 à un circuit d'embrayage / C surintensité
P1540 Air soupape de dérivation circuit dysfonctionnement
P1543 Compresseur d' air conditionné circuit de coupure
P1549 IMCC circuit dysfonctionnement Banque B
P1550 PSPS Hors gamme d'auto - test
P1565 vitesse commutateur de commande de contrôle Hors de portée haute
P1566 contrôle de la vitesse commutateur de commande Hors de portée faible
P1567 contrôle de la vitesse du circuit de sortie continuité
P1568 contrôle de la vitesse Impossible de maintenir la vitesse
P1571 frein dysfonctionnement du commutateur
P1572 frein pédale dysfonctionnement du circuit Position
P1573 Throttle Non disponible capteur de position
p1574 Throttle désaccord entre les capteurs de position de pédale de
P1575 Out of self plage de test position de pédale
P1576 Non disponible instantanée Nissan Trouble Codes spécifiques Code Description
P1320 Ignition signal P1211 ABS / TCS Unité
p1402 système EGR
P1491 Vacuum Cut Valve Bypass Valve
P1550 TCC Electrovanne P1605 A / T diagnostic Communication ligne
P1178 (ouverte )
P1187 Varient
P1191 Key tension de ligne P1192 tension externe
QQ blanc cours connect édition 110dci de 2011.
franck3
Messagepar franck3 » Jeu Juin 02, 2016 17:20
P1218 CID haute
p1244 échoué haut
P1366 Ignition
P1394 Glow
P1413 Low entrée
P1422 EGI
P1482 SCP
P1502 véhicule
P1526 Air
P1534 Inetia activé
p1402 système EGR
P1178 (ouverte )
P1187 Varient
P1218 CID haute
p1244 échoué haut
P1253 Pedal corrélation PDS1 & SDSFP Low P1254 Pedal corrélation PDS2 & SDSFP Haute
P1298
P1301 haute calibration Boost P1302 Low
P1366 Ignition
P1381 Calage variable Overadvanced (Banque n ° 1) / Misfire n'a détecté aucune communiction avec BCMP1382 ​​variable Cam timing solénoïde # 1 circuit Dysfonctionnement
P1394 Glow
franck3
P1413 Low entrée
p1420 Catalyst
P1422 EGI
P1482 SCPP1483 puissance au circuit du ventilateur surintensité
P1502 véhicule
P1505 de contrôle de l' air de ralenti à adaptatif Clip
P1526 Air
P1534 Inetia activé
soupape76
Messagepar soupape76 » Dim Avr 16, 2017 9:56
:D ces beaucoup plus clair en francais tbd4
Feel
Messagepar Feel » Sam Juin 10, 2017 12:33
Intéressant ce sujet et merci pour la traduction.
Mais avec quel matériel et quelle méthode utilisée peut on lire ces codes si cela se produit un jour .
alain74
Messagepar alain74 » Jeu Oct 26, 2017 4:52
Oui, où et comment trouver ces codes en cas de panne ? Quel matériel faut il avoir ?
Merci.
Qashqai +2 1.5 DcI octobre 2010
Messagepar titou78 » Jeu Oct 26, 2017 6:33
L'OBD 2 ne donne pas forcement les résultats souhaités car chaque marque à ses propres codes par model / motorisation / année de fabrication. tbd18
Utilisateurs parcourant ce forum : Mime, Uncle_BenZ et 6 invités
