[Topic Officiel] Keenlu KL8207G (NISSAN)
Messagepar Ce6 » Mer Déc 01, 2010 11:03
Brand: Keenlu
Model: KL8207G
Class: Special Car DVD Player
All-in-one Special Car DVD Player for Nissan / Hyundai / Kia
Nissan: Tiida, Bluebird, Cefiro, Paladin, Livina Geniss, Qashqai, Livina, Sylphy, X-Trail
Hyundai: Elantra, Sonata, Santa FE (old), Tucson, Terracan, Dawoo
Kia: Sportage, Cerato, Rio, Carens, VQ, Kia Wah, Carnival
Hot Selling Points:
1, V-6 disc changer memory
2, Built in RDS
3, PICTURE IN PICTURE FUNCTION
4, OSD menu have five languages for choice: English, Espanol, Italian, Deutsch, Francais
Features:
1, 6.2 inch 16:9 DIGITAL TFT LCD monitor
2, 800*480 touch screen: can select the tracks directly
3, unique 3D Flash Graphical User Interface
4, DVD/VCD/CD/MP3/MPEG4/DIVX/CD-R/WMA/JPEG
5, Built in TV tuner, PAL/NTSC or SECAM compatible
6, Built in FM/AM tuner/ RDS optional
7, Build in GPS or external GPS compatible (optional)
8, Dual zoon: You can listen music or radio while in GPS navigation
9, Build in BLUETOOTH for hand free call, history log, dial keyboard
10, IPOD function
11, DVB-T TV (optional)
12, Auto rear viewing function
13, USB jack and SD card slots for MP3, WMA, MP4, AVI, JPEG files
14, Individuated DVD logo display (can change the DVD wallpaper freely by yourself)
15, V-6 disc changer memory (6 disc music can be memory in the unit while you listening the music)
16, PICTURE IN PICTURE FUNCTION
17, All keys supply red and blue LED, match your original car perfectly
GPS Features:
Map supported: PDA FORMAT
Operation system: Windows CE 6.0
Processor: SAMSUNG High performance processor S3C2440A-40, Max.main frequency 400MHZ.
Display output : CVBS+S-VIDEO output. (Resolution:800*480) or simulation RGB output .
GPS specification: Adopt SiRF STAR III 20 channel and excessive high sensitivity GPS receiving module REB-3310, Orientation sensitivity reach -159dBm, Orientation presicion<10M,Orientation time of cold boot is 42S,Orientation time of warm boot is 35S,Orientation time of hot boot is 1S
Product Specification
Power 12V DC (allowable range:10.8-14.5V)
Grounding system Negative pole type
Maximum consumption of current 15A
Weight 4kg
Color As you see in the picture
Display screen
Size/horizontal-vertical ratio
6.2 inch/16:9
Pixel 800X480
Type TFT active matrix
Color system Full system
Range of operating temperature -20 degree Celsius to 70 degree Celsius
Range of storing temperature -30 degree Celsius to 80 degree Celsius
Angle regulation 0 degree Celsius to 50 degree Celsius
Audio Information
Maximum output power
45W x 4
Load impedance
4 ohms (allowable range:4-8 ohms)
Advance output level
4.0V/200 ohms
Encoder
Linear PCM/Dolby digital /Dolby professional edit 2/DTS
System Details
System DVD audio, DVD video, VCD, CD, DTS CD and Mp3 system
Discs available DVD audio disk, DVD video disk, VCD, CD, DTS CD
Number of tracks 2 (stereo), digital 6 tracks
MP3 encoding format MPEG-1, MPEG-2 and Audio level 3
FM frequency range 87.5-108.0 MHZ
FM effective sensitivity 10 DB (S/N:30DB)
AM frequency range 531-1, 629KHZ(9KHZ)
AM effective sensitivity 30DB(S/N:20DB)
GPS System
Operating System Win CE6.0
GPS Processor Samsung S3C2440A-40
Main Frequency 400Mhz
EMS Memory 64MB
Support Map TOMTOM DestinAter I-GO Route 66 Finean Smart2go
GPS Channel 20 Channels
Track sensitive - 159dBm
MAX Support SD Card Memory size 4GB
GPS Map Soft SD Card
Support audio MP3/MP4/WMA
Support video ASF/AVI/WMV/Divx
Video decode capability QVGA>25VSYC/ S
GPS Antenna 27dB/come with Out ceramic GPS antenna(length:3M)
Communication Port:COM2
BAUD Rate:9600
Unique Functions
GPS Yes
Dual zone Yes
Bluetooth Yes
Ipod feature Yes
3D Flash GUI Yes
USB/SD Cards Yes
Picture-in-picture Yes
Auto rear viewing Yes
Steering wheel control Yes
FAQ:
Q : Le nom des stations radio est-il affiché ?
R : Le nom des stations et titres des chansons sont inscrits sur l'écran, pour autant que la station écoutée diffuse le titre.
Q : De combien de RAM dispose le Keenlu ?
R : 128Mo
Q: Est-il possible d'écouter la musique en même temps que la navigation ?? si oui, le son se coupe ou il diminue ??
R: Il peut jouer de la musique, la radio, Mp3, vidéo en même temps que la navigation.
On choisis d'interrompre ou non l'écoute par le gps lors de messages....
Q: l'interface est-il en Français ?
R: Oui, l'interface est Français.
Deux modèles disponible, avec et sans TNT
Sans TNT pour Environ 346,93 € chez rt010175
Avec TNT pour Environ 382,82 € chez rt010175
http://www.keenlu.com/en/ProductView.as ... &SortID=69
http://www.wincalcd.com/en/index.php
http://www.wincalcd.com/en/products_view.php?id=71
Clés USB testées :
Par Carlito:
Marques: Intenso
Capacité: 4Go
Formatage: FAT32
Tuto d'installation du poste et prise Usb :
:arrow: viewtopic.php?p=158474#p158474
Re: [Topic Officiel] Keenlu KL8207G (NISSAN)
Messagepar yger » Mer Déc 01, 2010 12:33
Merci Ce6, ça va intéresser pas mal de monde !!!!
tbd3
bigmanu
Messagepar bigmanu » Mer Déc 01, 2010 12:40
Et le père noël nous l'apporte sous le sapin ou bien? (en fait je veux bien connaitre le prix du joujou :wink: )
Messagepar yger » Mer Déc 01, 2010 12:45
Tu peux le trouver là :
http://www.autoradiodvdgps.com/autoradi ... tooth.html
ou en relisant les dernieres pages de ce sujet sur les Autoradios 2 din compatibles : viewtopic.php?f=14&t=2814&st=0&sk=t&sd=a
Mais je suis sûr que Ce6 va nous redonner le prix !!!???
:wink:
Messagepar Ce6 » Mer Déc 01, 2010 13:09
J'ai édité le premier message :wink:
bigmanu
Messagepar bigmanu » Mer Déc 01, 2010 13:44
Merci, c'est vrai que j'ai été un peu feignant de la souris sur ce coup la :P
opalimages
Messagepar opalimages » Ven Déc 03, 2010 8:16
Il est dans mon QQ (Aïe :D ) depuis une petite semaine. Je découvre peu à peu les fonctionnalités -sympas- du zinzin.
J'ai du mal avec la TNT, qui ne trouve pas de signal, quelque soit l'endroit où je suis.
Montage terminé, il me reste 3 faisceaux de câbles inutilisés. Je connais la destination de l'un, grâce à Carlito (Merki, merki, merki) qui semble avoir déjà cerné totalement l'engin.
Peut-être que dans les deux qui restent, il y en a un pour la TNT (?)
Idem au niveau du QQ : j'ai deux bornier qui restent inutilisés. Je suppose que l'un des deux correspond au micro intégré dans le véhicule, mais l'autre ?
J'ai du mal aussi avec le GPS (Igo8) : fonctionne très bien, belle interface, mais la voix est une catastrophe (comparée à celle de mon bon vieux tomtom). Au secours ! un ptit lien ? :wink:
Bref, pour résumer, bel engin, mais une bonne notice, EN FRANCAIS !, ne serait pas superflue.
opalimages
Messagepar opalimages » Ven Déc 03, 2010 22:20
opalimages a écrit :mais la voix est une catastrophe (comparée à celle de mon bon vieux tomtom). Au secours ! un ptit lien ?
Je m'auto-cite, parce que j'ai trouvé !!! :D.
Si ça interesse qqun,n'hésitez pas à me contacter :wink:
Messagepar yger » Ven Déc 03, 2010 22:30
N'hesites pas à nous communiquer tes trouvailles, ton lien pour changer la voix peux surement intéresser pas mal de monde !!! :)
opalimages
Messagepar opalimages » Ven Déc 03, 2010 22:37
Ce n'est pas un lien : j'en avais effectivement trouvé un, mais c'était pour Ipod ou autre chose (j'ai tellement cherché que je ne sais plus). En revanche, j'ai bidouillé le fichier téléchargé (notamment en le renommant) pour le rendre compatible avec Igo.
Si qqun m'explique où et comment l'héberger (1,3mo), pour que vous puissiez le télécharger...
Messagepar Ce6 » Ven Déc 03, 2010 22:38
dl.free.fr :wink:
opalimages
Messagepar opalimages » Ven Déc 03, 2010 22:47
Merci Ce6
Fichier donc disponible ici : http://dl.free.fr/mP3UdycXi
Aprés téléchargement, ouvrir la micro SD => fichier IGO => iGO8 => Content => Voice
Et là, y glisser-déposer (ou coller) le fichier en question.
Après, réinsérer la sd dans le keenlu, réglage GPS, et charger (dans les voix françaises) la voix nommée "renée améliorée". Savourez la différence !
Messagepar Ce6 » Ven Déc 03, 2010 22:51
@opalimages, tu n'utilises pas les voix TTS ?? :shock:
opalimages
Messagepar opalimages » Ven Déc 03, 2010 22:53
gloops ! Y'en a sur la sd fournie ?
Messagepar Ce6 » Ven Déc 03, 2010 22:56
Bouge pas, je te fais une archive
